Fiat 128 Berlina 1500 SOHC
  • Fiat 128 Berlina 1500 SOHC
    Hello, this is my car for everyday use
    Engine:1500 SOHC from Lancia Delta
    Lightened, balanced flywheel cca 2,5kg
    Weber 32 DMTR from Fiat 128 rally
    Digiplex 2 ignition
    Electric fuel pump with pressure regulator MALPASSI
    Exhaust 4-2-1 fi 50mm
    Gearbox 17 64 Diff. ratio 5 speed from Yugo
    Brakes from Uno Turbo 240mm
    Aluminium sway bar mounts with Poyamid PA6
    Front arms from Yugo Florida (10mm longer than the Fiat 128 orginal)
    Rear arms from Zastava Poly double bottomed
    Wheels Smoor Roadster 7X13 ET 20
    Tyres DUNLOP SP 2000 175 50 13
    Front coilovers-homemade with aftermarket
    Rear coilovers-
    Coilovers for Fiat 128/Yugo
    Coming soon to the car
    Cat Cams racing camshaft 300degrees 10.20mm lift, Dellorto 45 side draft carburetors, with new intake manifold and filters
    uskoro 300stupnjeva 10,20mm lift
      Wow!!! Welcome to the forum! Really nice car
        thanks
          New wheels is here
          PLS Hockhenheim
          2 is 7x13 et 20
          2 is 7,5x13 et 24
            PLS
              Hello again,
              New set short gear ratios is inside
              Diff ratio is 17 64
              Feeling is very good but very short for everyday use on this diff ratio!
              In 5th gear on 7000 rpm I go 160km/h
              Acceleration is awsome!!
              I"m buy diff ratio 19 64
              This pictures is serial gearbox from Ritmo, and new short gear ratios
              Picture that was taken from a car driving in fifth gear on tyres 175 50 13
                Reconditioned Dellorto 45 DHLA with new manifold, filters and linkage set coming soon on 1,6 engine...
                Set New but very old tyres Pirelli P7F 175 50 13
                  webers 36 DCNF and 4-2-1 manifold is instaled
                  Very soon comming cynderhead with 40 35 mm valves, camshaft 299....
                    Very cool car.
