Fiat Coupe 20vt Plus
  • Fiat Coupe 20vt Plus
    Hi guys.My name is Alex and I own Coupe 20vt Plus from 1999.I did lot of modifications to the car.
    For now I drive with GT2871R,3" exhaust,440ccm injectors,ported head and manifolds,FC Performance map,walbro 255,3.8 FPR etc.The car stands on D2 coilovers and polybushed wishbones.Wheels are 18" from Alfa Romeo Mito.Rear lights are converted with Hella led lights.The engine is forged with Woessner pistons and Pauter con rods.
    My plan is to make it 4x4 from Alfa 155.So if anyone knows for a cheap Alfa please let me know.
    This setup I have ,I am driving from 2010.It is working without problems.But recently I bought everything new so I will soon tune it up again.
    Here are the pictures of my current setup.
ID:	258344Click image for larger version
ID:	258345Click image for larger version
ID:	258347Click image for larger version
ID:	258348Click image for larger version
ID:	258349Click image for larger version
ID:	258351Click image for larger version
ID:	249476Click image for larger version
ID:	249477Click image for larger version
ID:	249478Click image for larger version
      Mind = blown.
      Welcome! Im looking forward to follow this.
        Thank you mate.I am real Coupe freak.
        There are lot of things I missed like rear anti roll bar whiteline 24mm,front from Dedra integrale,welded subframe,stainless steel brake hoses,uprated wastegate,forge dump valve,Hks boost controller,front mount intercooler,modified crankshaft pulley,AEM wideband gauge,RAID oil temperature,exhaust gas temperature,boost pressure etc.I will post a pictures later because i need to go to work now.
          That's a super nice car
          Have you been to RR and checked HP/Nm?
          Do you have a stage 4 map from FC Performance?
          Good luck with the 4x4 conversion. I have also thought about this but so far only a dream. Maybe when the kids are bigger I can pursue it.......
          More pics here: http://www.garaget.org/?car=348031
          P.S Please add pics of the interior/dash. I would like to see where you have installed the gauges.
            Finally! Welcome to the forum!
            I think I have a friend with a Q4 for sale.. It's in a good shape but the crank bearings are gone.
              Good job with the car! Looks lovely, I like the black rims and that the car looks stock. I'm also curious about hp/nm! Do you have your car in Gothenburg or Serbia? Hoping to see it on some track day in Sweden
                Thanks a lot guys for a worm welcome.
                My car is stage 4 mapped from FC Performance and well known Flea.Unfortunatelly i did not go to RR so I do not know exact power of the engine for now.Most important is that everything is working well and with no problems.As I said I bought everything for stage 5 from Flea but I did not had a time to install it because I received a call to come here in Sweden.I hope I will do it soon.
                The plan is to make it 4x4 so the power goes down to the road properly.So Per if your friend wants to sell that Alfa please let me know.I am interested.The engine is not important to me,only transmission.
                The car is here with me in Gothenburg now.I do not drive it a lot,it is parked in the garage.
                Sorry Freddan I could not find in my computer any pictures of the gauges.I will take some tomorrow and I will post as soon as possible.
                For now I have these.
ID:	249493Click image for larger version
                The other one is from my friend.
ID:	249495Click image for larger version
ID:	249496Click image for larger version
ID:	249497Click image for larger version
ID:	249498Click image for larger version
ID:	249499Click image for larger version
ID:	249500Click image for larger version
ID:	249501Click image for larger version
                  I see that you have bought a set of Fiveo injectors. Are you going to use them in the next project (stage 5)? What cc?
                  Do you have any plans this weekend? I would like to meet you and check out your car
                  Please send pm if you can.
                    Yes the injectors are from Fiveo.They are now on the car.For stage 5 I received another injectors,bigger of course.Also Flea sent me big maf conversion,external fuel pump and colder spark plugs.Another stuff is mostly from Germany like Tial external wastegate,Spa turbo manifold,parts from the downpipe etc.
ID:	249503Click image for larger version
ID:	249504Click image for larger version
                    I will let you know about weekend Freddan.Looking forward to meet you.
                      Stage 4 is like at least 360bhp, right? Too bad that I live far away, I would like to have a look at your car as well.
                        It should be something between 350 and 400 bhp.Low setup is on 1.2 bar for every day and 1.5 bar hi setup limited because of the gearbox(just in case).
                          Never seen that manifold before, interesting..
                          Yeah I think it might be time for a coffee meet soon, so we (all westcoasters) can meet.
                          I'll ask Tomas about his 155.
                            That manifold is oftenly used in Brasil on Mareas.Its from cast iron and made by company called Spa turbo.Its pretty cheap compared to tubular manifolds,but still its good up to 600 bhp.You can buy it T25 and T3 options and with or without external wastegate.My new turbo will be GTX30 turbo which I bought from GIKTurbo.
                              Link to SPA Turbo: http://www.spaturbousa.com/
                              On page 9 you can see the manifold:
                              Price: $325 circa 2200 SEK.
                              It looks okay. Maybe you should make a cut between the pipes (like original one) to prevent it from cracking.
                              Why do you want an external WG? Is it better than internal WG?
