Fiat Coupe 20vt Plus
    Thanks a lot.
    Of course i have seen the video.
    Very soon I will change the turbo and install new setup.
    After that I am in pursuit to find 4wd drivetrain.
      I installed all 4 new tyres,changed from 215 to 225/35/18.
ID:	250207Click image for larger version
ID:	250208Click image for larger version
      Looks better visualy,its more comfortable too.We will see about the handling soon.
        XL = reinforced sidewall Are you planning to go sideways a lot?
          Not sure yet,we will see my friend.
          If I go AWD who knows?
            Hi guys.I need some longer bolts for wheels,anyone knows where to buy them?
              This is how I did it!
              Manton Racing should have it all.
              I think you even see the telephone nr at the spacer :-)
              JH
                OK thanks a lot
                  Bojke!
                  What setup do you use for your D2?
                  JH
                    What do you mean?
                      How hard/soft have you set up your coilovers front/rear
                      JH
                        How thick are your spacers? On www.ebay.co.uk I found mine, there are excenter bolts too. I bought 60mm bolts and cut them down to my perfect length. Look for M12x1.25 wheelbolts.
                        Single, longer bolts are always better than spacers with 8 bolts or nuts.
                          Yup!
                          And fixed bolts makes it easier to handle aswell. I just cut mine in the inside end to right length.
                          Spacers are 16mm in the front and 14mm rear..
                          and suddenly I realize that I answer Per and thought it was thread owner :-)
                          JH
                            My spacers are 20mm with longer bolts in the frond and 18mm in the back.
                            Before this Kumho tyres I had Falken which are much harder.The ride now with Kumho is much softer so turned my coilover setup to hardest and a ride is still comfortable.
                            • #44
                              Back to home,and new stage is up.
                              New turbo,exhaust manifold,external Tial wastegate,Flea chip,bigger injectors,and few more things.
ID:	250297Click image for larger version
ID:	250298Click image for larger version
ID:	250299Click image for larger version
ID:	250300Click image for larger version
ID:	250301Click image for larger version
ID:	250302Click image for larger version
                              • #45
                                Fiat Coupe heaven :O
