U1601 ser jag inte i listan på felkoder för Punton, i alla fall den lista som jag sitter på.
Postar alla U koder som jag har för Punto 1.2 med motorkod 188A4.
EOBD code Fault location
U0001 Controller area network (CAN) data bus, high speed bus
U0002 Controller area network (CAN) data bus, high speed bus - performance problem
U0003 Controller area network (CAN) data bus, high speed bus (+) - open circuit
U0004 Controller area network (CAN) data bus, high speed bus (+) - voltage low
U0005 Controller area network (CAN) data bus, high speed bus (+) - voltage high
U0006 Controller area network (CAN) data bus, high speed bus (-) - open circuit
U0007 Controller area network (CAN) data bus, high speed bus (-) - voltage low
U0008 Controller area network (CAN) data bus, high speed bus (-) - voltage high
U0009 Controller area network (CAN) data bus, high speed bus (-) - shorted to data bus (+)
U0010 Controller area network (CAN) data bus, medium speed bus
U0011 Controller area network (CAN) data bus, medium speed bus - performance problem
U0012 Controller area network (CAN) data bus, medium speed bus (+) - open circuit
U0013 Controller area network (CAN) data bus, medium speed bus (+) - voltage low
U0014 Controller area network (CAN) data bus, medium speed bus (+) - voltage high
U0015 Controller area network (CAN) data bus, medium speed bus (-)
U0016 Controller area network (CAN) data bus, medium speed bus (-) - voltage low
U0017 Controller area network (CAN) data bus, medium speed bus (-) - voltage high
U0018 Controller area network (CAN) data bus, medium speed bus (-) - shorted to data bus (+)
U0019 Controller area network (CAN) data bus, low speed bus
U0020 Controller area network (CAN) data bus, low speed bus - performance problem
U0021 Controller area network (CAN) data bus, low speed bus (+) - open circuit
U0022 Controller area network (CAN) data bus, low speed bus (+) - voltage low
U0023 Controller area network (CAN) data bus, low speed bus (+) - voltage high
U0024 Controller area network (CAN) data bus, low speed bus (-) - open circuit
U0025 Controller area network (CAN) data bus, low speed bus (-) - voltage low
U0026 Controller area network (CAN) data bus, low speed bus (-) - voltage high
U0027 Controller area network (CAN) data bus, low speed bus (-) - shorted to data bus (+)
U0028 Vehicle area network (VAN) data bus A
U0029 Vehicle area network (VAN) data bus A - performance problem
U0030 Vehicle area network (VAN) data bus A (+) - open circuit
U0031 Vehicle area network (VAN) data bus A (+) - voltage low
U0032 Vehicle area network (VAN) data bus A (+) - voltage high
U0033 Vehicle area network (VAN) data bus A (-) - open circuit
U0034 Vehicle area network (VAN) data bus A (-) - voltage low
U0035 Vehicle area network (VAN) data bus A (-) - voltage high
U0036 Vehicle area network (VAN) data bus A (-) - shorted to data bus A (+)
U0037 Vehicle area network (VAN) data bus B
U0038 Vehicle area network (VAN) data bus B - performance problem
U0039 Vehicle area network (VAN) data bus B (+) - open circuit
U0040 Vehicle area network (VAN) data bus B (+) - voltage low
U0041 Vehicle area network (VAN) data bus B (+) - voltage high
U0042 Vehicle area network (VAN) data bus B (-) - open circuit
U0043 Vehicle area network (VAN) data bus B (-) - voltage low
U0044 Vehicle area network (VAN) data bus B (-) - voltage high
U0045 Vehicle area network (VAN) data bus B (-) - shorted to data bus B (+)
U0046 Vehicle area network (VAN) data bus C
U0047 Vehicle area network (VAN) data bus C - performance problem
U0048 Vehicle area network (VAN) data bus C (+) - open circuit
U0049 Vehicle area network (VAN) data bus C (+) - voltage low
U0050 Vehicle area network (VAN) data bus C (+) - voltage high
U0051 Vehicle area network (VAN) data bus C (-) - open circuit
U0052 Vehicle area network (VAN) data bus C (-) - voltage low
U0053 Vehicle area network (VAN) data bus C (-) - voltage high
U0054 Vehicle area network (VAN) data bus C (-) - shorted to data bus C (+)
U0055 Vehicle area network (VAN) data bus D
U0056 Vehicle area network (VAN) data bus D - performance problem
U0057 Vehicle area network (VAN) data bus D (+) - open circuit
U0058 Vehicle area network (VAN) data bus D (+) - voltage low
U0059 Vehicle area network (VAN) data bus D (+) - voltage high
U0060 Vehicle area network (VAN) data bus D (-) - open circuit
U0061 Vehicle area network (VAN) data bus D (-) - voltage low
U0062 Vehicle area network (VAN) data bus D (-) - voltage high
U0063 Vehicle area network (VAN) data bus D (-) - shorted to data bus D (+)
U0064 Vehicle area network (VAN) data bus E
U0065 Vehicle area network (VAN) data bus E - performance problem
U0066 Vehicle area network (VAN) data bus E (+) - open circuit
U0067 Vehicle area network (VAN) data bus E (+) - voltage low
U0068 Vehicle area network (VAN) data bus E (+) - voltage high
U0069 Vehicle area network (VAN) data bus E (-) - open circuit
U0070 Vehicle area network (VAN) data bus E (-) - voltage low
U0071 Vehicle area network (VAN) data bus E (-) - voltage high
U0072 Vehicle area network (VAN) data bus E (-) - shorted to data bus E (+)
U0073 Control module - data bus Off
U0100 Data bus, engine control module (ECM) A - no communication
U0101 Data bus, transmission control module (TCM) - no communication
U0102 Data bus, transfer box control module - no communication
U0103 Data bus, gear shift module - no communication
U0104 Data bus, cruise control module - no communication
U0105 Data bus, injector control module - no communication
U0106 Data bus, glow plug control module - no communication
U0107 Data bus, throttle actuator control (TAC) module - no communication
U0108 Data bus, alternative fuel control module - no communication
U0109 Data bus, fuel pump (FP) control module - no communication
U0110 Data bus, drive motor control module - no communication
U0111 Data bus, battery energy control module A - no communication
U0112 Data bus, battery energy control module B - no communication
U0113 Data bus, emissions critical control information - no communication
U0114 Data bus, four wheel drive clutch control module - no communication
U0115 Data bus, engine control module (ECM) B - no communication
U0121 Data bus, anti-lock brake system (ABS) control module - no communication
U0122 Data bus, vehicle dynamics control module - no communication
U0123 Data bus, yaw rate sensor module - no communication
U0124 Data bus, lateral acceleration sensor module - no communication
U0125 Data bus, multi-axis acceleration sensor module - no communication
U0126 Data bus, steering position sensor control module - no communication
U0127 Data bus, tyre pressure monitor module - no communication
U0128 Data bus, parking brake control module - no communication
U0129 Data bus, brake system control module - no communication
U0130 Data bus, steering effort control module - no communication
U0131 Data bus, power steering control module - no communication
U0132 Data bus, suspension ride height control module - no communication
U0140 Data bus, body control module (BCM) - no communication
U0141 Data bus, body control module (BCM) A - no communication
U0142 Data bus, body control module (BCM) B - no communication
U0143 Data bus, body control module (BCM) C - no communication
U0144 Data bus, body control module (BCM) D - no communication
U0145 Data bus, body control module (BCM) E - no communication
U0146 Data bus, gateway A - no communication
U0147 Data bus, gateway B - no communication
U0148 Data bus, gateway C - no communication
U0149 Data bus, gateway D - no communication
U0150 Data bus, gateway E - no communication
U0151 Data bus, supplementary restraint system (SRS) control module - no communication
U0152 Data bus, supplementary restraint system (SRS) control module, left - no communication
U0153 Data bus, supplementary restraint system (SRS) control module, right - no communication
U0154 Data bus, supplementary restraint system (SRS) occupant sensing control module - no communication
U0155 Data bus, instrumentation control module - no communication
U0156 Data bus, information centre A - no communication
U0157 Data bus, information centre B - no communication
U0158 Data bus, head up display - no communication
U0159 Data bus, parking aid control module A - no communication
U0160 Data bus, audible alert control module - no communication
U0161 Data bus, compass module - no communication
U0162 Data bus, navigation display module - no communication
U0163 Data bus, navigation control module - no communication
U0164 Data bus, AC control module - no communication
U0165 Data bus, AC control module, rear
U0166 Data bus, auxiliary heater control module - no communication
U0167 Data bus, immobilizer control module - no communication
U0168 Data bus, alarm system control module - no communication
U0169 Data bus, sunroof control module - no communication
U0170 Data bus, supplementary restraint system (SRS) sensor A - no communication
U0171 Data bus, supplementary restraint system (SRS) sensor B - no communication
U0172 Data bus, supplementary restraint system (SRS) sensor C - no communication
U0173 Data bus, supplementary restraint system (SRS) sensor D - no communication
U0174 Data bus, supplementary restraint system (SRS) sensor E - no communication
U0175 Data bus, supplementary restraint system (SRS) sensor F - no communication
U0176 Data bus, supplementary restraint system (SRS) sensor G - no communication
U0177 Data bus, supplementary restraint system (SRS) sensor H - no communication
U0178 Data bus, supplementary restraint system (SRS) sensor I - no communication
U0179 Data bus, supplementary restraint system (SRS) sensor J - no communication
U0180 Data bus, automatic lighting control module - no communication
U0181 Data bus, headlamp level control module - no communication
U0182 Data bus, lamps control module, front - no communication
U0183 Data bus, lamps control module, rear - no communication
U0184 Data bus, radio - no communication
U0185 Data bus, aerial module - no communication
U0186 Data bus, audio unit output amplifier - no communication
U0187 Data bus, digital disc player/changer module A - no communication
U0188 Data bus, digital disc player/changer module B - no communication
U0189 Data bus, digital disc player/changer module C - no communication
U0190 Data bus, digital disc player/changer module D - no communication
U0191 Data bus, television - no communication
U0192 Data bus, personal computer - no communication
U0193 Data bus, digital audio control module A - no communication
U0194 Data bus, digital audio control module B - no communication
U0195 Data bus, subscription entertainment receiver module - no communication
U0196 Data bus, entertainment control module, rear - no communication
U0197 Data bus, telephone control module - no communication
U0198 Data bus, telematics control module - no communication
U0199 Data bus, door function control module A - no communication
U0200 Data bus, door function control module B - no communication
U0201 Data bus, door function control module C - no communication
U0202 Data bus, door function control module D - no communication
U0203 Data bus, door function control module E - no communication
U0204 Data bus, door function control module F - no communication
U0205 Data bus, door function control module G - no communication
U0206 Data bus, convertible top control module - no communication
U0207 Data bus, moveable roof control module - no communication
U0208 Data bus, seat adjustment control module A - no communication
U0209 Data bus, seat adjustment control module B - no communication
U0210 Data bus, seat adjustment control module C - no communication
U0211 Data bus, seat adjustment control module D - no communication
U0212 Data bus, steering column control module - no communication
U0213 Data bus, mirror control module A - no communication
U0214 Data bus, remote function actuation - no communication
U0215 Data bus, door contact switch A - no communication
U0216 Data bus, door contact switch B - no communication
U0217 Data bus, door contact switch C - no communication
U0218 Data bus, door contact switch D - no communication
U0219 Data bus, door contact switch E - no communication
U0220 Data bus, door contact switch F - no communication
U0221 Data bus, door contact switch G - no communication
U0222 Data bus, electric window motor A - no communication
U0223 Data bus, electric window motor B - no communication
U0224 Data bus, electric window motor C - no communication
U0225 Data bus, electric window motor D - no communication
U0226 Data bus, electric window motor E - no communication
U0227 Data bus, electric window motor F - no communication
U0228 Data bus, electric window motor G - no communication
U0229 Data bus, heated steering wheel module - no communication
U0230 Data bus, tailgate control module - no communication
U0231 Data bus, rain sensor control module - no communication
U0232 Data bus, side obstacle detection control module, left - no communication
U0233 Data bus, side obstacle detection control module, right - no communication
U0234 Data bus, convenience recall module - no communication
U0235 Data bus, cruise control front distance range sensor - no communication
U0300 Control module - internal software incompatibility
U0301 Software incompatibility - engine control module (ECM)
U0302 Software incompatibility - transmission control module (TCM)
U0303 Software incompatibility - transfer box control module
U0304 Software incompatibility - gear shift module
U0305 Software incompatibility - cruise control module
U0306 Software incompatibility - injector control module
U0307 Software incompatibility - glow plug control module
U0308 Software incompatibility - throttle actuator control (TAC) module
U0309 Software incompatibility - alternative fuel control module
U0310 Software incompatibility - fuel pump (FP) control module
U0311 Software incompatibility - drive motor control module
U0312 Software incompatibility - battery energy control module A
U0313 Software incompatibility - battery energy control module B
U0314 Software incompatibility - four wheel drive clutch control module
U0315 Software incompatibility - anti-lock brake system (ABS) control module
U0316 Software incompatibility - vehicle dynamics control module
U0317 Software incompatibility - parking brake control module
U0318 Software incompatibility - brake system control module
U0319 Software incompatibility - steering effort control module
U0320 Software incompatibility - power steering control module
U0321 Software incompatibility - suspension ride height control module
U0322 Software incompatibility - body control module
Software incompatibility - instrumentation control module
U0324 Software incompatibility - AC control module
U0325 Software incompatibility - auxiliary heater control module
U0326 Software incompatibility - immobilizer control module
U0327 Software incompatibility - alarm system control module
U0328 Software incompatibility - steering position sensor control module
U0329 Software incompatibility - steering column control module
U0330 Software incompatibility - tyre pressure monitor module
U0331 Software incompatibility - body control module A
U0332 Software incompatibility - multi-axis acceleration sensor module
U0400 Invalid data received
U0401 Invalid data received - engine control module (ECM)
U0402 Invalid data received - transmission control module (TCM)
U0403 Invalid data received - transfer box control module
U0404 Invalid data received - gear shift module
U0405 Invalid data received - cruise control module
U0406 Invalid data received - injector control module
U0407 Invalid data received - glow plug control module
U0408 Invalid data received - throttle actuator control (TAC) module
U0409 Invalid data received - alternative fuel control module
U0410 Invalid data received - fuel pump (FP) control module
U0411 Invalid data received - drive motor control module
U0412 Invalid data received - battery energy control module A
U0413 Invalid data received - battery energy control module B
U0414 Invalid data received - four wheel drive clutch control module
U0415 Invalid data received - anti-lock brake system (ABS) control module
U0416 Invalid data received - vehicle dynamics control module
U0417 Invalid data received - parking brake control module
U0418 Invalid data received - brake system control module
U0419 Invalid data received - steering effort control module
U0420 Invalid data received - power steering control module
U0421 Invalid data received - suspension ride height control module
U0422 Invalid data received - body control module
U0423 Invalid data received - instrumentation control module
U0424 Invalid data received - AC control module
U0425 Invalid data received - auxiliary heater control module
U0426 Invalid data received - immobilizer control module
U0427 Invalid data received - alarm system control module
U0428 Invalid data received - steering position sensor control module
U0429 Invalid data received - steering column control module
U0430 Invalid data received - tyre pressure monitor module
U0431 Invalid data received - body control module A
u1600 samt u1601 är stöldskyddets felkoder båda coderna är inget att bry sig om då den sätter dom felkoderna dagligen . Ena blir om man vrider nyckel till startläge innan codelampan slocknar , andra blir närman fipplar med tändnyckeln eller har mycket skit hängandes på nyckelknippan.
