Läsa datakoder från ECU... intresting
  • Läsa datakoder från ECU... intresting
    Är det någon som testat eller har ett alternativ ?
    http://www.pcelectronics.org/shop/item1356.html
    http://scantool.net/screenshots_features.htm
    http://scantool.net/screenshots_features.htm#sensordata
    OBS träffade just på detta !
    Skulle ingå software "scantool" med denna plugg !
    We make ourselves gladly the trouble over you a correct Tool to the hand to give. Therefore you get one also only from us into current version of Scantoolnet with graphic revision .
    In addition we have multilinguale version of OBDGauge (Palmversion) with which we to have participated.
    We are located in direct contact with the software developers around also in the future versions to make available to be able to your needs correspond."
    OBD2 diagnostic interface V2.0 for all KFZ with ISO 9141/14230/KWP2000-Protokoll!
    USB version!
    New Design!
    Microprocessor technology!
    Inclusive 5m USB cable connection
    and
    different freely available diagnostic software
    among other things a Handheld version for Palm
    The interface has an integrated OBD-2 plug
    And be based on a ELM323 Microcontroller of the company ELM Electronics, no adapter problems by integrated USB technology!
    Naturally in the newest version 2.0
    The interface is put directly into the diagnostic socket of the vehicle!
    An LED signals supply voltage
    The four other LED signal the data traffic on the bus.
    Tip of us:
    The LEDS are not only decoration but supply with start-up important information, lie close the board tension, can the computer with the interface communicate, communicate the KFZ with the interface?
    If you exclude yourselves once the screen with your computer, then you know the LEDS are as important.
    What can one make thereby?
    - selections and delete from error codes (DTC)
    - approx.. 3000 general ones and manufacturer-specific codes stored.
    - in connection with it, data read from Freeze Frame
    - deletion of the MIL
    - selections and processing of operational data in real-time
    - can be communicated over an integrated terminal program directly with the controller.
    Fiat for FUN
    Kollade på det där för ett tag sedan. Mycket intressant, har dock kommit några andra projekt ivägen för detta.
    Länk:
    http://www.digimoto.com
    De har färdiga paket med både mjukvara och hårdvara. Då jag tittade på det här var det dessutom ett attraktivt pris, även med frakt och svensk moms insräknad. Har också för mig det fanns någon svensk representant.
      Ser ut att vara liknande !
      En 1000 lapp kan det va värt !
      Tänk på vad man får betala för att bli lurad vid service ! mm.
      Värt att tänka på när det börjar jävlas jämfört med att lämna in blåögt o betala 3000 för inget !
      Fiat for FUN
        grymt
        Vad funkar det på för bilar, går det t.ex. på coupens databox (Marelli) och Punto GT:ns (Bosch Multipoint)?
        Om den är unviersal och funkar på det mesta är det ju riktigt grymt.
        /Fredde
        Fiat Punto GT - Turbo for fun
